Hey -
Why?: I had a bunch of issues with getting my set up running and trawled these forums for a solution with no luck.
After getting it to work after several hours of trying every combination, I managed to find a configuration that worked for me, so I thought I'd post it here in the hope someone might be looking for a thread like this.
Firstly, I am not an expert at all, just another DJ, so if this doesn't work then we have different cards/systems.
This set up is for a laptop (Vista, Realtech HD audio), HERCULES, and amp or mixing desk, using RCA leads (the red and black plugs -audio out on the Hercules).
Firstly check that your herc has the green tick.
Go Start>Control Panel>Sounds - under the playback tab you should see it ticked, if this is not the case just select the Hercules at default by right clicking on it.
IMAGE LINK: http://img830.imageshack.us/img830/8174/unled1cc.jpg
Starting up VirtualDJ in the top right hand corner click "CONFIG"
This is my set up.
4.1 card - Hercules DJ consol
IMAGE LINK: http://img148.imageshack.us/img148/3697/unled2f.jpg
I know there are alot of people doing different things, but I figured this is a nice easy set up for those on a PC laptop.
I hope this helps someone.
This is my set up.
geposted Thu 05 May 11 @ 2:25 am
BTW - if anyone knows the codes to embed images, I'd love to have my little J-Pegs show up. Nothing I attempted worked, if I am not allowed to post images maybe a mod could do it for me? ... cheers...K
geposted Thu 05 May 11 @ 3:06 am
