Hi All,
I use a lot of Cues in my tracks and quite often the first cue starts after say 30 secs to the song. What I have seen that for some songs when I load it on a deck the song is already set on the first cue but quite often I have seen for other songs even if there are multiple cues marked on the song(s), the song will load at the first block of the CBG. Why is that and what can I do to ensure that all my songs will load at the first cue, plz..
Many thanks again
Many thanks again
geposted Thu 05 May 11 @ 5:56 am
Go into Config >>> Options and make sure Auto Cue is set to Enabled. That should sort out your issue. If you have multiple cue points in a track, use the stop button to cycle through your cues.
geposted Thu 05 May 11 @ 7:55 am
"Go into Config >>> Options and make sure Auto Cue is set to Enabled. That should sort out your issue. If you have multiple cue points in a track, use the stop button to cycle through your cues."
Thanks a lot superaceman for your response. The settings are correct at the moment in my Vdj as mentioned in my posting that it works for some songs and for others it do not. And yes I do use stop button currently to cycle through but what I want is when I first load the song it should be ready to play from Cue 1.
I think I just found the problem. For some songs the first Cue is actually Cue 2 (in terms of the number). It is for those songs it is not loaded at the first Cue position.
Thanks for the help.
geposted Thu 05 May 11 @ 4:40 pm
