Hi Guys!New here.
Well I got a Numark Ndx800 and the problem is that I have only 1+Behringer DJX700
So I connected it via USB to Virtual DJ and everything was fine,BUT only 1 problem.
The effects I can use with the Numark cannot be used(It uses the Virtual DJ's efx)
So my question is:Can I somehow insert the effects from the NDX to the Virtual DJ?
Thanks all! ♥
Thanks all! ♥
geposted Fri 06 May 11 @ 2:30 pm
No you can use the numarks effects because its in MIDI mode, you can only use the numarks effects when your in CD mode.
geposted Sat 07 May 11 @ 1:51 am
Well is it possible with any other program or the MIDI issue stays? :(
and can you please tell me your oppinion about the NDX800?
geposted Sat 07 May 11 @ 7:23 am
It's not possible with any application in MIDI mode. In MIDI mode the buttons simply send a signal to the software to tell it that button has been pressed. In VirtualDJ, the button can be mapped to any internal VDJ effect or other function of your choice.
Effects built into these CD players will only work when using the NDX-800 with audio CD's or USB media.
NOTE: The full VirtualDJ Pro is required to use the NDX-800's or any other MIDI controllers: https://virtualdj.com/buy/
geposted Sat 07 May 11 @ 1:06 pm
