Hey Guys Im Having A problem maping my DJM800 I Have the MIDI cable and all is set up but when i go to map it nothing happens!! I press the midi button and it says start but nothing please help thanks!!
geposted Fri 06 May 11 @ 4:15 pm
since i upgraded to version 7 i lost all......
cant load my saved midi map of version 6
this really sucks
this really sucks
geposted Sat 30 Jul 11 @ 10:39 am
Where can i download version 6 again, this is going nowhere... i have tried with the learn function, it recognizes the input of the midi, but it doesn't preform it afterwards... on top of this i noticed that loop and cue doesn't make differences between left and right deck anymore..
I want my 6 back where can i download?
geposted Sun 31 Jul 11 @ 1:01 am
First off - nothing changed from version 6 to 7 that would cause the SimpleMIDIWrapper to break.
The file you posted is not from version 6 - it was from the old version 5 or older. We switched the controller support method in version 6 (2 years ago).
Because you are using the SimpleMIDIWrapper you have to distinguish which deck you want the action to perform on --
deck 1 loop
deck 1 cue
So when you look at your old mapping ... the chan="#" is the deck number.
deck 1 loop
deck 1 cue
geposted Sun 31 Jul 11 @ 8:10 am
Thats all great in all, and i just checked indeed it was version 5... since i indeed in retrospect didnt upgrade to 6.
However that doesnt take away that it doesnt work as it finds the midi input signal but but after the learn it doesnt work...
where can i download the version 5?? i dont care for any new functions (if any) you put in as it does not add anything for me.
geposted Sun 31 Jul 11 @ 9:40 am
Spend another 3 hours trying to make this work, since i cant download old versions of the software (where are they?).... i uploaded the wrong file btw...
I modded some other presets and it still doesnt work properly. Useless things like assigning eq to a rotary knob seem to be working (who would want to use internal vdj eq)...
I want to assign the fader start buttons to loop in loop out DOESNT WORK
I want to assign the middle two faders to effect on and off DOESNT WORK
What does work..
Assigning middle two cue buttons to sync desk 1 and 2.
now i need only a very few options....
Now i think here is the issue:
my old file.
<ctrl ctrl="88" mode="slider" action="loop_in" chan="1" />
<ctrl ctrl="90" mode="slider" action="loop_in" chan="2" />
<ctrl ctrl="89" mode="slider" action="loop_out" chan="1" />
<ctrl ctrl="93" mode="slider" action="loop_out" chan="2" />
<ctrl ctrl="71" mode="slider" action="loop" chan="1" />
<ctrl ctrl="18" mode="slider" action="effect_activate" chan="1" />
<ctrl ctrl="75" mode="slider" action="sample_play" scale="0" />
<ctrl ctrl="72" mode="slider" action="loop" chan="2" scale="0" />
<ctrl ctrl="19" mode="slider" action="effect_activate" chan="2" scale="0" />
New file
<map value="0-CC88" action="deck 1 loop_in" />
<map value="0-CC89" action="deck 1 loop_out" />
<map value="0-CC90" action="deck 2 loop_in" />
<map value="0-CC93" action="deck 2 loop_out" />
<map value="0-CC71" action="deck 1 sync" /> (works!!!!!!!!)
<map value="0-CC72" action="deck 2 sync" /> (works!!!!!!!!)
<map value="0-CC18" action="deck 1 effect active" />
<map value="0-CC19" action="deck 2 effect default active" />
seems that the control vs action has to be matching, so button vs button in the software press on screen and knob vs knob in the software
What does work..
my old file.
New file
geposted Sun 31 Jul 11 @ 8:04 pm
geposted Tue 02 Aug 11 @ 10:11 pm
nobody that can help?
geposted Sat 06 Aug 11 @ 11:18 pm
I cant get my Dj2Go to work with Virtual DJ PRO 7
Hi Technical People,
I cant get my Dj2Go to work with Virtual DJ PRO 7.
when i open up virtual dj le lite my dj2go MIDI lights up straight away and i can use it instantly.
when i open up virtual dj pro 7 my dj2go MIDI doesn't light up and it has no effect of the programme.
what is wrong???
what is wrong???
geposted Tue 20 Sep 11 @ 12:23 pm
Cracked version of pro maybe for starters, and this is a DJM thread?
geposted Tue 20 Sep 11 @ 12:31 pm
Please register your Pro serial number on the page https://virtualdj.com/users/edit.html and then download the latest version from https://virtualdj.com/download/updates.html
If you still can't get it to work after doing this, please open a new topic on this subject rather than hi-jacking an existing topic that is not related to your question in any way. This topic is about MIDI mapping the Pioneer DJM-800 mixer.
geposted Tue 20 Sep 11 @ 12:38 pm
