Hi all,
I'm still fairly new to VDJ, but I've got it set up with my NS7 to do video quite nicely.
Question - How can I set it up so that the crossfader affects the video only? I'd like to control the audio with the up/down faders, and the video with the crossfader.
Thanks!
Thanks!
geposted Fri 06 May 11 @ 5:03 pm
The easiest way is to go to CONFIG -> Options and set the crossfader to disabled.
Make sure that you have it linked to the video crossfader in CONFIG -> Video and it will now control the video crossfader only.
Alternatively, you can change the mapping for CROSSFADER in CONFIG -> Mappers -> Numark NS7 to video_crossfader instead of crossfader.
geposted Sat 07 May 11 @ 12:32 pm
Thanks for this, works perfectly with the first method. However for some reason, the program won't save the Crossfader: Disabled setting. It keeps reverting back to "User" when I restart the VDJ. Am I missing something?
Thanks again!
Thanks again!
geposted Wed 18 May 11 @ 10:11 am
If the NS7 has a crossfader curve knob, then this may be sending its current position to VirtualDJ at start-up, forcing the crossfader back to the appropriate user setting.
To check, go to CONFIG -> Mappers -> NS7 and look for the mapping crossfader_curve and change it to: crossfader_curve "disabled"
Alternatively, change the crossfader mapping to video crossfader as above. The crossfader will then always act as a video crossfader only.
geposted Wed 18 May 11 @ 12:17 pm
