ok now my problem is i got another hc4500 controller and when i go to sound setup it only says speaker 2 denon hc4500 on sound card option and i only get sound out of the left side and both decks play off from same side. how do i get it to split let and right channels?
geposted Fri 06 May 11 @ 6:52 pm
I assume you use a 4 ch external mixer , correct?
You need to use the Advanced Sound config and ASIO mode (drivers)
Deck 1 ...Denon ASIO ..output 1&2
Deck 2 ..Denon ASIO .output 3&4
Deck 3 .. Denon ASIO .. output 5&6
Deck 4 .. Denon ASIO ..output 7&8
geposted Fri 06 May 11 @ 10:12 pm
yes i am using the denon xo50 mixer
geposted Fri 06 May 11 @ 10:52 pm
can you show me step by step on how to do this? i need it for tomorrow i am stressing out
geposted Fri 06 May 11 @ 10:57 pm
how do i install the asio drivers?
geposted Fri 06 May 11 @ 11:06 pm
The correct setup for Denon DN-HC4500 on PC is:
Inputs: None
Outputs: External Mixer
Sound card: Denon ASIO (Make sure that you have the latest ASIO driver and firmware installed from http://www.denondj.com )
NOTE: The HC4500 has a 4 out (2 stereo) sound card. It does not have enough outputs for 4 decks. For 4 decks, you would need to use an external sound card wish 8 outputs (4 stereo) such as Native Instruments Audio 8 DJ.
Inputs: None
geposted Sat 07 May 11 @ 12:55 pm
ok the hc4500 has version v1006 update and i just downloaded the denon asio driver let try this
geposted Sat 07 May 11 @ 3:16 pm
