I was wondering if anyone has ever tried to connect an Ipod though a Hercules RMX? I tried last night and couldn't figure out what settings to use. Anyone ever try it? Thanks.
geposted Mon 09 May 11 @ 3:10 pm
You will need a coonection from your ipod to a red and white rca connection to either input 1 2 or 3 4 located at the back of the RMX play ipod and select either Source 1 or Source 2 from the panel. It should work, done it before.
geposted Mon 09 May 11 @ 8:02 pm
Bosabose, I tried that, and when I hit the source button I get a message on the deck saying Timecode Bypass and still no sound. I usually just hook into a regular mixer, and was trying to see if this would work. Thanks.
geposted Mon 09 May 11 @ 11:06 pm
Same problem here! I just ended up using this little 2 channel mixer I have and unplugged my 1/4in from the rmx into that felt embarrassing but that's the only way I got it to work.
geposted Tue 10 May 11 @ 2:36 pm
@DJnrgbear
What audio configuration do you have in VDJ ?
geposted Tue 10 May 11 @ 3:02 pm
DJ Phatso, Input=none Output=headphones Soundcard=RMX. I tried different combos but still nothing.
geposted Tue 10 May 11 @ 3:14 pm
