I need to expand the "Master Out" video screen on the skin to a larger size so the karaoke lyrics could be read more easily from the laptop monitor, in tight venues there is no room for a singers monitor and the display wall monitors position is not visible,,,, Could this be done when needed and set back when finshed..with a karaoke session..??
Thanks,
Joey...
Thanks,
Joey...
geposted Tue 10 May 11 @ 10:43 am
Have you tried using the pop up VDJ output monitor window Joey, maximise to desired size when needed, send to task bar when not needed.
geposted Tue 10 May 11 @ 12:01 pm
Of course this would be ideal if I wasn't using the extented monitors for the audience, is there another way?
geposted Tue 10 May 11 @ 12:15 pm
As an example the laptop screen would have the program skin and the center Output video screen expanded, something like the image all showing from within the laptop screen..
The window is usually docked in the upper left hand corner Box of the skin and is a smaller size by default to fit that box, but the video window could be Un-Docked moved and stretched to fit.
Thanks,
Joey
Thanks,
Joey
geposted Tue 10 May 11 @ 5:39 pm
It Doesn't have to be that complicated as the above example, If the center video screen window could be expended like in the image #2 in my second example below, then this would help to at least be more readable then the first image #1 which is the defult video screen window size.
Thanks,
Joey....
Image #1
Image #2
Thanks,
Joey....
Image #1
Image #2
geposted Wed 11 May 11 @ 4:58 pm
that looks like a switable panel with a larger screen joey.sure that can be done.or check the "Groove v.2" skin,its similar to the default skin but with added tricks....
geposted Fri 13 May 11 @ 3:55 am
Thanks
geposted Fri 13 May 11 @ 10:53 am
No problema Joey....:-)
geposted Fri 20 May 11 @ 4:54 am
