Hello All,
Sunday I switched over to ASIO from direct sound drivers. This was the best setup ever with low latency. I tried to open VDJ 7 and now it crashes at loading the sound engion. I had ASIO set to auto. My system is:
AMD 6 core 2.8
4gig Ram
M-Audio Delta 410 soundcard
ELO touchscreen.
Is there a way to change the audio setting in the registry?
Thanks?
EL
DJ at Large
AMD 6 core 2.8
4gig Ram
ELO touchscreen.
Thanks?
EL
DJ at Large
geposted Wed 11 May 11 @ 6:01 am
In HKEY_CURRENT_USER\Software\VirtualDJ, delete the following keys:
AdvancedSoundConfig
ASIODriver
ASIOMapChanIn
ASIOMapChanOut
DXDriver
SoundSetupCard
SoundSetupIn
SoundSetupInChan
SoundSetupOut
SoundSetupOutChan
Then launch VirtualDJ again
AdvancedSoundConfig
ASIODriver
ASIOMapChanIn
ASIOMapChanOut
DXDriver
SoundSetupCard
SoundSetupIn
SoundSetupInChan
SoundSetupOut
SoundSetupOutChan
geposted Wed 11 May 11 @ 12:01 pm
I can now get the program to open but when I click on config it crashes again.
EL
DJ at Large
EL
DJ at Large
geposted Wed 11 May 11 @ 8:22 pm
I think you have a drivers issue. You should install your audio drivers again.
geposted Thu 12 May 11 @ 12:44 pm
I went into regedit and deleted the VDJ folder and installed 7.0.4. Thanks for your help and the world is a better place!
EL
DJ at Large
EL
DJ at Large
geposted Thu 12 May 11 @ 10:40 pm
