I am having a problem with my Maya44 USB config with my Virtual DJ
So want to make sure how to reinstall which I have done twice but maybe no the correct way
Yes I do know about reusing the same USB when first installed
Now when I pop in the Maya44 USB CD software it does not pop up to run
So I open it in my computer under my PC disc drive
And hit download, which it does
Is there another way because I still ca not Config
Thanks so much for any help
geposted Wed 11 May 11 @ 10:00 pm
Download the latest drivers http://www.esi-audiotechnik.com/download/ESI/MAYA44_USB/MAYA44_USB-v2_928.zip
Extract the contents of that zip file to a folder and doubleclick on the setup.exe file.
Follow the instructions given here http://www.esi-audiotechnik.com/download/ESI/MAYA44_USB/MAYA44_USB-English.pdf
geposted Wed 11 May 11 @ 10:08 pm
The web site you sent me DID IT!!! I just had to change it to 64 bit.
We got music playin player!
But only on right side not left side?
geposted Wed 11 May 11 @ 11:13 pm
It also only plays on one side of my head phones at the same time to?
geposted Wed 11 May 11 @ 11:17 pm
I only have one side playing
My mixer shows only one side working
My head phones only have one side hearing
Speaker only has the tweeter playing
Just got done installing maya44 USB
geposted Thu 12 May 11 @ 9:55 pm
