Using a Laptop.
I have saved a playlist. (actually have saved it multiple times)
The playlist tab has a plus next to it but it will not open it.
Any suggestions?
I can pull up the history with no problem.
Any suggestions?
geposted Fri 13 May 11 @ 11:50 am
Once you click on the PlayList folder icon (In The Folder Window), it opens up all saved playlist, remember you need to apply a name before you save...
Good Luck,
Joey...
Good Luck,
Joey...
geposted Fri 13 May 11 @ 12:18 pm
I've saved playlist in Virtual DJ,but later on when i try to access it,titles are there but it wont load...now,i use a portable drive for all music,is the case that when i unplug the drive it has something to do with the playlist being lost,or does that have anything to do with it?
geposted Thu 11 Aug 11 @ 6:01 pm
