Hi, first sorry for my bad english.
When can we edit info directly in the browser?? like traktor...
and why Vdj can not catch all the info like rating or coment fields from itunes?
I would like this features in the future, thanks!!
geposted Sat 14 May 11 @ 7:58 am
Nobody knows if this features are upcoming soon?
geposted Sun 15 May 11 @ 8:20 am
you cant edit the information in the browser, but you could map a button to edit_info or edit_comment to make it a little quicker and easier
geposted Sun 15 May 11 @ 8:55 am
What feature is it exactly that you want, for those of us who doesn't use traktor. You can right click in the browser to edit the id3 tags of a track if that is what you mean?
geposted Sun 15 May 11 @ 8:57 am
He means like in iTunes, just click the field and edit, in explore, you highlight the file name carefully click 2x's and rename, a standard windows feature...
geposted Sun 15 May 11 @ 4:13 pm
Exactly JoeKJ...
And... why virtualdj doesn't sync rating column with itunes playlist? thanks!
geposted Mon 16 May 11 @ 1:54 am
Don't know, it's been asked for by many, maybe Apple has to ok it..?
geposted Mon 16 May 11 @ 2:34 pm
@monetdisco
I'll give you a tip, if you are playing a track and want to edit or rate on the fly while the track is playing hit "F" key on your keyboard and the track Info will open up from Deck #1. If you need Deck #2 then hit "G" on your keyboard.
If not programed then go to mapper Keyboard and enter ( Key: F and Action: deck 1 file_info for Deck #1) and ( Key: G and Action: deck 2 file_info for Deck #2).
Good Luck,
Joey....
Good Luck,
Joey....
geposted Mon 16 May 11 @ 2:52 pm
Thanks Joey!
geposted Mon 16 May 11 @ 3:47 pm
That will only work for mp3's though. Mp4's have to be unloaded off the deck first.
Huey
Huey
geposted Mon 16 May 11 @ 4:06 pm
