bondoir pouriez vous m'aidé , expliqué comment mettre a jour mes denon dns 1200. merci d'avance
geposted Sun 15 May 11 @ 8:39 pm
geposted Sun 15 May 11 @ 9:08 pm
en suite je fais quoi. aussi pourquoi mon denon dns 1200 reconnais pas ma clé usb
geposted Sun 15 May 11 @ 9:23 pm
The DN-S1200 offers two types of playback modes, as described
below.
To play tracks stored on a USB memory device, create a database.
Create the database using DB Create in the utility mode or using the
included “DENON DJ Music Manager“.
File Playback mode
MP3/WAV files are searched for and selected by artist name, album
name, genre, year, BPM, etc., and played in units of files.
Playlist Playback mode
Playlists created and edited by the user are searched for and selected
and the MP3/WAV files registered on that playlist are played. By using
playlists, the DN-S1200 can be operated with the same feel as
conventional CDs. Up to 1,000 playlists can be created per device. A
maximum of 99 MP3/WAV files can be registered on each playlist.
The play mode switches between the file play mode
and playlist play mode each time the PLAYLIST button is
pressed. The play mode can also be switched by selecting
“P-List Play” or “File Play” at the respective top menus.
The playlist play mode is set when the PLAYLIST button is
pressed and held in.
below.
File Playback mode
geposted Sun 15 May 11 @ 9:39 pm
s'l vous plais pouvez vous m'expliqué comment créé une base de donné dB. MERCI
geposted Sun 15 May 11 @ 9:55 pm
je vous ai donné un lien précédemment
http://www.denondj.com/firmware.aspx?ProductId=52
Téléchargez music manager en bas de la fenêtre en noire
Pour télécharger il vous faut déjà enregistrer votre matériel sur le site de denon et créer un compte
geposted Sun 15 May 11 @ 10:24 pm
pour pouvoire lire les cles usb sur les dns 1200 il faut:
appuyer sur source et selectionner USB
ensuite la la lecture de la cles se fait et les dns 1200 font une database sur la clée automatiquement.
geposted Tue 17 May 11 @ 9:56 am
