Hey Everyone I am looking for a skin that has BIG areas for artist and track name, I add info to these fields (intro, break, outro times etc...) and anytime i have a LOT of stuff to type in I find myself shortening artist names and mix names...
ANy thoughts on which skins are going to give me what i need?
(I'd prefer a skin with a 2 and 4 track version, but either way can be worked with...)
geposted Mon 16 May 11 @ 12:42 pm
i dont think that you can find a skin with artist-title large enough to view all those infos.
a. You can add those extra infos to comment or other VDJ field and use a skin with those fields on textzones.
b. You can view all those infos if the textzones have scroll enabled. The default one has. Click to the artist-title textzone to scroll.
c. Modify the skin you use. You will need some skining and script skills though.
geposted Mon 16 May 11 @ 9:37 pm
