Model: HP G70 Notebook PC
Processor: Intel Core 2 Duo CPU T6500 @ 2.10 GHZ
RAM: 3.00 GB
System Type: 32 Bit Operating system
System: Windows Vista
VDJ Edition: Home Edition Free
Skin: Virtual DJ 7 [4 Decks] 1440x900
I used to use the paid edition I bought for 50$ but it did not have the 4-deck skin so I have been using the free edition for about half a year. I have been using it in the past with no errors but recently for the past week all my live cues start seconds off. For example, if I have a cue set to start on (sound coming) 'Straight from the underground' in a song, when I press the cue button while playing it starts at 'he underground' or 'sound coming'. I have tried again over the past few days and my cues are still not working. I did not install any new software on my PC or modify anything major in VDJ.
Can anyone help please? Should I reinstall it, and if I do will it delete all the cues I have set in all 1,000 of my songs?
RAM: 3.00 GB
geposted Mon 16 May 11 @ 11:26 pm
Bump..
geposted Thu 09 Jun 11 @ 1:45 am
You probably have smart play or beatlock enabled.
Smart play can be enabled/disabled fom the 2 deck default skin (small padlock above play button). Alternatively you may assign a keyboard shortcut as deck 1 smart_play or deck 2 smart_play
Beatlock feature is available in the Scratch center mixer panel.
geposted Thu 09 Jun 11 @ 9:12 am
Thanks, I think it works now!
geposted Mon 20 Jun 11 @ 9:59 pm
