hi all
sorry if this has been asked before im wanting to get timecodes (serato vinyls) to work with an external mixer through my pc onboard soundcard is this possible? if not can any 1 recommend any cheapish soundcards that i can use i used to have a hercules rmx but sold it i was told i maybe able to the Creative Sound Blaster X-Fi Surround 5.1 if so how would i go about this please?
many thanks in advance
pinhead1000
pinhead1000
geposted Tue 17 May 11 @ 3:57 pm
that won't work, to mix with vinyl you need 2 stereo inputs and 2 stereo outputs if you want to use an external analog mixer, the cheapest option is the maya 44, but you would have to get something to ground the turntables on. Other options are torq connective, hercules deejay trim (comes with VDJ LE, NI audio 4, 6, 8, 10, serato 1-3
geposted Tue 17 May 11 @ 5:57 pm
hi synthet1c
thanks for the reply would i not be able to ground the turntables to the external mixer as normal? im starting to wish i had kept my rmx now and used that as a soundcard
many thanks
pinhead1000
many thanks
pinhead1000
geposted Wed 18 May 11 @ 1:28 am
sorry I must of had a lapse in brain function... yep you can ground on your mixer
geposted Wed 18 May 11 @ 1:49 am
hi synthet1c
lol we all get them days m8 i get them all the time again thanks for the reply its much appreciated i think i will go and buy the maya44 m8 as that seems like a nice option for the time being
many thanks for the help
pinhead1000
pinhead1000
geposted Wed 18 May 11 @ 4:14 am
