The browser header features tab heading such as Artist, Title etc.
How do you alter the size, after resizing to my resolution I need to increase at least two sizes.
geposted Tue 17 May 11 @ 6:10 pm
Open the xml file with Notepad or similar editor ...search for browser element (part) and change the size of the widgets line..
<browser>
<widgets font="arial" size="17" color="#ffffff" ......
</browser>
<browser>
</browser>
geposted Tue 17 May 11 @ 10:19 pm
Thank you DJ Dad.
I'm currently using the AVESv1.1 skin.
I noticed when I open the skin in notepad that there was a dropzone part, does this mean you can max the drop area of the song? if so this is good because unless you drop the song directly onto the progress bar it wont load on this skin. How do I increase dropzone to include the whole deck?
Also by default the time on this skin is set to elapse, can this be set to remain by default?
How about altering the size of the artist, title and info text in the decks. All info would be greatly appretiated.
geposted Wed 18 May 11 @ 4:47 am
Ahh sorted all that but then decided to use something else instead
geposted Wed 18 May 11 @ 11:26 am
