So I just picked up my Mixdeck today i am running VDJ 7.0.2 LE and I'm having a problem with a the cross fader. When i have it all the way to left and both tracks playing I hear both of the songs but when i move the fader to the right I hear nothing at all. If i have the fader all the way to the left i should only be hearing the song on the left but I am hearing both.
Any suggestions? Do i need VDJ pro or can i do it on LE?
Please help :)
Please help :)
geposted Thu 19 May 11 @ 10:13 pm
First, please ensure that you have the latest VirtualDJ LE v7 installed: https://virtualdj.com/download/updates.html
And the latest drivers and firmware from: http://www.numark.com/mixdeck
Then go to CONFIG -> Sound Setup and set your sound as follows:
Inputs: None
Outputs: External Mixer
Sound card: Numark
Click APPLY.
Make sure that the channels on the mixer section of the MixDeck are set to PC.
Inputs: None
Sound card: Numark
Click APPLY.
geposted Fri 20 May 11 @ 12:56 pm
that works unless recording it just records both decks at the same time....
geposted Tue 16 Aug 11 @ 9:41 pm
This is because the mixer section of the MixDeck is a real hardware audio mixer (Non-MIDI) - Please see https://virtualdj.com/wiki/Recording%20your%20set%20or%20broadcasting%20when%20using%20an%20external%20DJ%20mixer.html and https://virtualdj.com/wiki/MixDeck.html
geposted Wed 17 Aug 11 @ 7:09 am
thanks for the help worked out great!
geposted Thu 18 Aug 11 @ 10:10 pm
