Hi everyone!
I'm writing this post to see if im doing the right thing.
I have a hercules rmx and i had it for like a year, im ready to upgrade and i want to go the next level of djing so i was thinking of buying something better.
I have a budget of 1000 dollars and thats like the maximum I could afford. I was thinking of getting the Denon MC-6000 because it looks like a great equipment and its in my budget range, but i want to be sure that this is the best i can buy with that amount of money.
I would love to have a bigger set, but i don't really think i can afford one with only 1000 bux
So is this my best choice and the best thing and i can buy with that amount of money? Will it really feel more different that when i dj with the hercules rmx?
Thanks!
Thanks!
geposted Sat 21 May 11 @ 12:48 pm
That depends on your style of DJing. If you are a scratch Dj and like larger platters the NS6 might be more to your liking.
Any controller you switch to will have it's own feel to it.
For that price you could get a MC6K and a glyde style case, and have enough left over to upgrade to VDJ Pr.o The 6k is a solid piece of gear, and it is made for VDJ while the NS6 is not. If you are a mobile DJ and you do video or karaoke this in my opinion is your best buy.
geposted Sat 21 May 11 @ 2:33 pm
Im a house DJ, most of the music I play is Electro House or Progressive House. I don't really scratch a lot so if its good for scratching or not, its not really a problem.
I like playing more in raves or big house parties and i don't really do karaoke. I might get the Denon MC6000 because of the price and all the good reviews I found in the forum.
I really want to go more pro with my next equipment, I know it might not be the best or the more professional equipment but i think it does the job way better than the hercules rmx and the MC6000 looks more professional.
I don't have really big incomes so i don't want to buy something so expensive that later i regret of it, thats why I want to know if this is the best I can get for what I want with the budget limit i have.
Thanks
Thanks
geposted Sat 21 May 11 @ 2:44 pm
pioneer ti
geposted Sat 21 May 11 @ 3:05 pm
Yeah I was thinking about the Pioneer one, but i saw a lot of bad comments about it and its not completely compatible with Virtual DJ
geposted Sun 22 May 11 @ 1:13 am
