Hi Everyone,
Is There A Way That When I Change The position Of The Track
(On the TimeLine) The Song Will be kept In Sync Like In Traktor?
geposted Sat 21 May 11 @ 6:54 pm
you need to engage Beatlock to the Slave deck. You can find the beatlock function in the Scratch center panel (default skin), or use a sortcut mapped as
beatlock
beatlock
geposted Sat 21 May 11 @ 9:45 pm
you could also use
goto : 'goto +16' will go forward 16 bars staying in time with where the track is currently playing, you can also use 'goto -8' to go backwards, you can use any number you like
goto_bar : put the song on its nth beat after the downbeat without loosing sync: 'goto_bar 4'
geposted Sat 21 May 11 @ 10:46 pm
