I use virtual dj homeedition 5 and all of the skins that are for the resolution of my screen dont work for the version of virtual dj that i have. The resolution of my screen is 1366 x 768. I tried the skin resizer program but it doesnt work for me. Is there anyway that someone can either help me make a skin for this? I like the mix lab v3.1 skin but since it is 1280 by 780 it wont fit on my screen correctly.
I would really appreciate it if someone can take and make those changes in that skin for me to be able to use it with my software.
Thanks
Thanks
geposted Sun 22 May 11 @ 7:42 pm
