Hi guys, i have i little problem with every skin i try to use thing is :
I cant find one that have N/S function , but can work on VDJ 7.
I dont know do you know about that becouse few skins have it so i will try to explain:
It was on few skins like , Pioneer CDJ-100S by Paky G, Pioneer CDJ-200S, CDJ-700S... and other.
Its on players when u play song with S/N OFF you can spin the record and scratch but when N/S option is on you can use it to fine match songs, becouse sometimes SYNC doesnt match right.
Something similar is also on MIX Station SV4 only it doesnt write N/S its like little wheel on center of record, also when u turn with that little wheel you can fine match songs.
And in new versions of VDJ that option doesnt work on skins i have used years before like the ones i wrote up.
Is there any skin that supports N/S function in VDJ7 , please help guys.
I hope i managed to describe good ....
geposted Mon 23 May 11 @ 1:27 am
