Does anybody knows if the denon mc6000 asio drivers can be use for windows media player or iTunes I mean convines, normally I use iTunes to play some backing trucks for our band, and I use vdj for video display it was ok with my mixdeck, but with the mc6000 they cancel eachother can only have working. If open both non work. Any ideas? Thanks
geposted Tue 24 May 11 @ 3:51 am
Asio drivers only allow one input source. you can always use your PC sound card for itunes and a line out from your laptop to the MC6000
Keith
Keith
geposted Tue 24 May 11 @ 4:06 am
Ok for some reason I was able to do it with my mixdeck.. Do you have mc6000? If so can you please share you settings for some reason is not working the video from denon.. I just wanna have it as 2 deck unit for vdj, and the other 2 for external use for backup.
geposted Tue 24 May 11 @ 4:32 am
geposted Tue 24 May 11 @ 8:15 am
I'm having the same problem with background music and the karaoke pluin tracks , after many hours of testing I figured out how to accomplish this;
1. Click off the two little lock icons over the software fader.
2. Make deck B the main deck by clicking the small "M" icon to light up.
3. Load the AutoMix playlist with your Backing tracks, Activate Autoplay and stop play with your controller.
4. Make deck A the main deck by clicking the small "M" icon to light up.
5. Drag the software fader over to deck A (And Leave It There, Don't Move It).
6. Deck A will now be your main deck for Djin'
7. Use your Volume Levels in deck B to fade in your tracks (Not The Fader).
This will let you use deck "A" independently from deck "B" (Your backing Tracks Deck) and control both decks from your controller...
Good Luck,
Joey...
geposted Tue 24 May 11 @ 8:58 am
