I bought some cd+g original cds but cant play them on virtual dj. ive read about ripping them into mp3 files and things like that but i dont know what to do. I have a pc with windows vista. Please help.
geposted Tue 24 May 11 @ 10:05 am
Use Audiograbber to rip the cd, get it here http://www.audiograbber.org/download.html
Use Mp3+G Tools 4 to zip the files, get it here http://www.activeaspsoftware.net/default.aspx?p=home
Note: under options in Mp3+G set the compression to no more then 5..
Good Luck,
Joey...
Good Luck,
Joey...
geposted Tue 24 May 11 @ 11:31 am
Sorry, VirtualDJ cannot play CD+G directly from the original CD's. Only audio CD's are supported (To allow you to play tracks at short notice from a CD that you have not yet ripped to MP3, or a customer's CD.)
To play karaoke in VirtualDJ, you will need to 'rip' these to standard MP3+G format (See above.)
NOTE: You will need to purchase the full VirtualDJ Professional to play karaoke and/or video full-screen: https://virtualdj.com/buy/ - All other versions are limited to a small output window only.
geposted Tue 24 May 11 @ 12:18 pm
I have both of those programs insalled on my computer now but still dont understand what to do and how to do it. please give me some guidence
geposted Tue 24 May 11 @ 2:58 pm
have a look in the wiki section.... https://virtualdj.com/wiki/Video_General.html
geposted Tue 24 May 11 @ 3:15 pm
The Mp3+G Toolz, all you have to do is right click on the karaoke file folder (where you saved the ripped karaoke tracks) and choose Mp3+G Toolz.net, at the main menu choose (Convert Audio+G To Zip), once done Open VDJ find the karaoke folder, right click and add to search, then drag a file to a deck and press play.....Don't forget to change the compression rate to 5 under options in Mp3+G.
Audiograbber, this is a fairly simple program to use and also has the added feature you are looking for to play CDG tracks from the CD. Below is a image of how to rip tracks into your HD, but I'm giving you the link again to read the tutorial so you can understand how to operate it's features..
Link http://www.audiograbber.org/maintour.html
Good Luck,
Joey...
Good Luck,
Joey...
geposted Tue 24 May 11 @ 4:51 pm
