Hope somone can help. I downloaded the mappers available thru vdj for the t1. I installed and used it at home just to check it out. I had a show later that day and did not bring my t1 with me. I use a separate sound card when I use vdj at a gig. As i was sound checking before the show I noticed this bing or like a piano key whold strike whenever the sync light would light up. it was audible over the music. and has never done that until I installed the mappers for the t1. I disabled midi devices and the bing went away and so did the functionality of my sound card. I really need to eliminate that rediculous noise. I have looked through every option in the config screen and nothing will eliminate the noise. if you have installed the mappers for the t1 run run vdj with out the t1 hooked up and try to see f you can replicate the bing. Its weird whenever I check on midi devices in the mapper screen i get piano keys and chords sounding, its wierd like i said. Please help. also now deck a or 1 will start to play as soon as i slide the cross fader over or bring the volume up. I need to remedy that also. Thanks for your help
geposted Tue 24 May 11 @ 3:20 pm
Yes, it is because you don't have the unit connected. So, the device mappings are still being sent to the generic midi device of the OS.
The device header of the definition file is incorrectly defined - this is why you are experiencing the problem.
geposted Tue 24 May 11 @ 5:09 pm
how do I go about defining the device header? I would like to fix the issue
geposted Tue 24 May 11 @ 7:19 pm
Here maybe this page can help you, https://virtualdj.com/wiki/Controller_Definition.html
Hope that helps
Huey
Hope that helps
Huey
geposted Tue 24 May 11 @ 7:26 pm
Hey guys, the guy at the top mentioned he downloaded the mappers for the t1.
i cant see em! lol can someone give me a direct link
cheers!! :)
cheers!! :)
geposted Fri 24 Jun 11 @ 12:29 am
I need a mapper for ddj-t1 but im not a pro user can someone give me a link pls. help I dont want to use traktor i always use Virtual DJ...
geposted Sat 08 Oct 11 @ 1:40 pm
Then purchase a legal license so you can register it and get access to all the available goodies.
geposted Sat 08 Oct 11 @ 1:56 pm
has anyone got an updated mapper for the ddj T1 ?
geposted Sun 01 Jul 12 @ 8:18 am
has anyone found anupdated mapper for ddj T1 where the leds work on the platters?
geposted Sun 01 Jul 12 @ 8:19 am
Please stop asking questions about the DDJ-T1 in every related thread you can find.
Use one thread and ask all your questions there.
Thank you
Keith
Thank you
Keith
geposted Sun 01 Jul 12 @ 10:57 am
