I have some songs (i.e. Taio Cruz - Dynamite (Ultimix mix)) that the CBG is fine through most of the song then after a break about 2/3 the way into the song the CBG gets off just a little bit. I have tried to reanalyze these songs but that doesn't work. Does anyone know if the BPM is changing during these songs or any other possible scenerio's why this would happen? I thought maybe it was a file format issue (I use FLAC) but since it lines up in the beginning didn't think it was that.
Thanks,
Kris
Thanks,
Kris
geposted Wed 25 May 11 @ 11:27 am
most likely its the song itself
geposted Thu 26 May 11 @ 12:02 pm
i have seen the same thing happen for some of my songs too. The CBG is off but the BPM is still the same, i think it is just something about that particular file. just nudge the next song coming in and you should be fine.
geposted Sat 18 Jun 11 @ 6:36 pm
....I had a similar problem....it was my beatlock being engaged and not realizing it
geposted Sat 18 Jun 11 @ 11:55 pm
