The wiki isn't very detailed at all. I'm trying to figure a couple things out.
For one, I want to be able to set the volume of a sampler to the volume of the active deck. I can't seem to figure out the proper way to nest things. The get_text command seems to allow `deck 2 get volume` inside the text to return data from another command, but it doesn't seem to work for anything else: sampler 8 volume `deck 2 get volume` (tried with and without single/double quotes).
Addtionally, how can I perform complex multi-command things while_pressed? For instance, sampler 8 play & deck 2 volume 0% while_pressed
I want both things to reset (stop playing and reset volume to whatever it was) on release.
geposted Wed 25 May 11 @ 12:23 pm
You were really close... It should be
sampler 8 play while_pressed & deck 2 volume 0% while_pressed
Every time you use '&' you have to write a whole script again for the action you want.
Unfortunately you can't use "get" to make a query so that won't work, you should also note that the sampler plays at its own volume and for some reason this cant be set at 0db like the decks, so you have to do it manually.
geposted Wed 25 May 11 @ 12:32 pm
When I use that method, only one of them resets (the first one) so the sampler stops playing on release, but the deck doesn't unmute.
I'm fine with the sampler not muting, I just want to make a sort of variable overdub effect using the sampler. My first button starts recording, and the second button stops recording on press and starts looping it as long as I hold it, muting the deck during playback, and then unmuting and stop sampler playback on release. I want the sampler volume to match deck volume so the volume doesn't suddenly shoot up when I'm at 80% on the deck and 100% on the sampler.
geposted Wed 25 May 11 @ 2:19 pm
Actually, I was remembering wrong. When I use this command:
sampler 8 stop_rec & deck 2 volume 0% while_pressed & sampler 8 play while_pressed
The both happen when I press down, but then nothing happens on release. When I tap it again, it stops playing the sampler but doesn't change the volume back. Removing the first section "sampler 8 stop_rec &" doesn't change this result
geposted Wed 25 May 11 @ 6:56 pm
this works fine on my computer... Are you using a midi controller? "while_pressed" doesn't work on the keyboard because keys repeat themselves when held down like thissssssssssssssssssssssssss lol
geposted Thu 26 May 11 @ 3:18 am
Tried using 3 different midi controllers :(
geposted Thu 26 May 11 @ 7:11 am
Bump. started a new thread
geposted Fri 27 May 11 @ 12:19 pm
Are self-bumps allowed (as I ironically self-bump :P)? Any other ideas on this?
geposted Tue 31 May 11 @ 11:07 pm
Nup not allowed!... LOL
If you are using your limited Edition they only work with the specific controller that you have bought, so you will need to update to pro to be able to map controllers, If your not using LE you should buy pro but... What controllers did you use? They may not be supported by VDJ. In that case you should be able to use simple midi to map them, otherwise you will need to create a definition file. https://virtualdj.com/wiki/Controller_Definition.html
geposted Wed 01 Jun 11 @ 3:06 am
I'm just remapping a regular button on my RMX
geposted Thu 02 Jun 11 @ 11:07 pm
The button is already mapped in the definitions, all I'm doing is changing the VDJ script commands that happen for that MIDI button
geposted Mon 13 Jun 11 @ 7:20 am
