Okay here is the package I have put together for beginning lights. Please give me your thoughts on it and provide any feedback or adjustments to this package:
1 - American DJ Revo 4
1 - Chauvet Hurricane 1300 Fog
2 - American DJ Mega Bar 50RGB
1 - American DJ Crank II Mobile Trussing System
1 - American DJ MyDMX Lighting Control (Going to look for cheaper alternative)
2 - American DJ Aggressor Tri LED
1 - American DJ PC-100A 8-Switch ON/OFF Power Center
I can get this package for around 1100-1200.00, what would you change?
geposted Wed 25 May 11 @ 8:20 pm
look on cheaplights.com
geposted Wed 25 May 11 @ 9:46 pm
Add 2 ADJ Micro Galaxians into that package and it would be a solid setup with plenty of options.
geposted Wed 25 May 11 @ 9:56 pm
I had a similar budget and here is what i went with - the real question is are you going to take the time to really use the DMX controller and program all of your lights? I knew as a mobile DJ with changing venues and different setups from gig to gig I probably wouldn't take the extra time to program them all and my friends that DJ too told me that they almost always used the "music reactive mode" on their lighting.
I am also into symmetry, both for the effects and for the looks of the rig so here is what I ended up with
2 x ADJ Reflex LED ($150 Each)
ADJ Majestic Centerpiece ($200)
Chauvet Hurricane 1300 Fog Machine ($100) Absolutely love it ! my 3rd fog machine and by far the best
ADJ Dura Truss Crank system with extra truss section 15 ft total. - much sturdier than the Crank II and with the extra length I fly my speakers on the ends (QSC K10) $400 - i got mine on craigslist for $200
2x Chauvet st-2000 strobe lights w/ ch751 controller ( $115)
PC-100 8-switch outlet center ($30)
$1100
Edit - Ok just saw you had 2 aggressors on there guessing 1 of those on each side and the revo-4 in the middle that would look good :)
Lighting is really subjective since you get a lot of the same effects from a ton of different options.
I also found you can get a pretty cool effect by shooting one of the cheap green turantula lasers at an 8" mirror ball
$1100
geposted Wed 25 May 11 @ 9:58 pm
Keeping everything else and just adding two of Micro Galaxians?
geposted Wed 25 May 11 @ 10:10 pm
Yes Aggressors on the ends and Revo4 in the center with the Light Bars between them. That is the plan. I have added two Micro Galaxians and possibly remove the DMX controller for now. Yes in the future I plan on using full blown DMX but not initially.
geposted Wed 25 May 11 @ 10:13 pm
LEDs make any lights and sound tricks better
Online Childrens Furniture Stores - Kids Bedroom Furniture Sets
Website Marketing
Website Marketing
geposted Wed 25 May 11 @ 11:52 pm
Website Marketing
Website Marketing
Good point! and I agree
geposted Thu 26 May 11 @ 7:00 am
I am ordering everything! Hopefully it will look good!
geposted Thu 26 May 11 @ 5:16 pm
MyDMX is extremely easy to program. All the lights profilers are there and it tells you what switches to move on the lights in a little picture. Good choice.
geposted Thu 26 May 11 @ 6:08 pm
Actually I dropped the MyDMX for now and picked up two Micro Galaxian lights. My next purchase will be the myDMX!!
geposted Thu 26 May 11 @ 7:45 pm
Have you looked at the WiTech8?
geposted Thu 26 May 11 @ 8:17 pm
Thats pretty sweet! I may look into that until I get full DMX'ed
geposted Thu 26 May 11 @ 8:33 pm
