So im having a problem were I am opening Virtual DJ and a window pops up and asks me to download the new version and I do. So i down load them and install them. But when i go back to virtual DJ the same window pops up and the old version is till in use. Any help?
Thanks,
JJ
Thanks,
JJ
geposted Thu 26 May 11 @ 3:40 pm
If you have icons on your desktop and/or dock, then these may still be pointing at the previous version.
Please use the VirtualDJ Pro icon found in Applications (Not VirtualDJ, which is the old version and may still be present.)
To avoid confusion, you can delete the old icons if you do not need them.
geposted Fri 27 May 11 @ 6:37 am
That's exactly it. I had both icons in applications and the old icon on the tool bar. Get rid of the old applications and 7.04 will be left over to use...thanks!
geposted Fri 27 May 11 @ 12:50 pm
