I have my DN-MC6000 all set up per the manual for 2 deck operation. The microphone works fine out of the speakers and headphones, however I cannot record any microphone audio. Is it possible to also capture the microphone audio in the recording?
geposted Thu 26 May 11 @ 7:05 pm
Yes it can be done, there is a switch on the back.of the unit you need to change then it will send mics to VDJ for recording.
Keith
Keith
geposted Fri 27 May 11 @ 5:14 am
Do you mean the Output Source switch? I have it set to REC OUT/MIC . Should I have it set to CH 1/4 ?
I definitely have the microphone activated on the top panel, and whether or not I hit the "POST" button it doesn't seem to make a difference.
geposted Fri 27 May 11 @ 10:47 am
