help jut instaled vj on a new laptop but cant seem to get it playing on both decks, , using an sl1 sound card bt also tred my old maya card, HELP GOT A BIG GIG TOMORROW!!!!!.. am getting 100% on 1 but nothing on the other one
geposted Fri 27 May 11 @ 5:29 pm
well now i got it working on both decks but the sound doesnt come out on both channels... meaning if i play the right deck it plays on the right channel of the sound system if i play the left it plays on the left channel... am getting 100% on both decks in timecode but only 1 channel at a time for audio
geposted Sat 28 May 11 @ 9:52 am
make sure your mixer and soundcard are properly plugged in first then... if you are using advanced config make sure you have not selected "mono channels" it is for people who only have one output but want dual channel mixing. If your not using advanced config I recommend it as you can set up all the ins and outs yourself and use multiple cards or have other daws slave to VDJ
geposted Sat 28 May 11 @ 10:16 am
