Is there a plug-in I need, and how do I set the configurations?
Ive read somewhere about Shoutcast already being built into VDJ, if so, how do I set it up? Anything that sets me off into the right direction helps!
Thank you for your time.
geposted Tue 31 May 11 @ 4:22 pm
Thanks guys you all are so much help
geposted Wed 01 Jun 11 @ 8:55 am
Hi,
have you seen this informations?
https://virtualdj.com/wiki/Broadcasting%20Howto.html
https://virtualdj.com/forums/59741/Virtual_DJ_Radio/The_Ultimate_Guide_to_Broadcasting_With_Virtual_Dj.html?page=1
You can select two different ways.
1) Broadcast from your own computer
You are yourself the radios station with your own computer.
You listners connects to you you at home.
The limit to your listener count, is your upload speed.
It is just a / Example 2.000kbits Upload : 128bkit = Max 15Listener
2) Broadcast to a radio station like VDJ Radio.
You use the second option and you stream to the radio server elsewhere.
The listener connect to this server :-)
geposted Wed 01 Jun 11 @ 9:02 am
I just set this up and it was very simple.
I used listen2mymusic.com
Created an account with them and used the password they provided to setup broadcast using VDJ 7
Very easy..
Very easy..
geposted Mon 13 Jun 11 @ 3:14 pm
