I was looking through the forums and couldn't find the answer to this. That or I wasn't searching the right topics. Here's the problem:
I have VDJ 7 LE running on my Denon DN MC-6000. Everything works perfect except if I use my EFX to much the program closes out on me. I have noticed it does it more if I am using the center select knob to search through the EFX. It some time's does it when I use the EFX 1 knob to search through the efx. I have updated the software but still no luck. Any ideas would be much appreciated and as always thanks for everyone's time and consideration on this matter.
Eli
Dj-TeK
Eli
Dj-TeK
geposted Tue 31 May 11 @ 8:25 pm
So you mean the program just disappears and the music stops?!
If that's what you mean, then I think I had that problem a little while ago and it turned out to be a "bad" effect with some sort of problem. Try it a few times (not at a gig!) and see if it always crashes when you scroll past a certain effect. If it looks like it's always the same one, try deleting it, or moving to a different folder on the computer so vdj doesn't see it and try again.
Hope that helps.
Hope that helps.
geposted Wed 01 Jun 11 @ 2:45 am
Ill have to try that, thanks for the tip!
geposted Thu 02 Jun 11 @ 2:09 am
