so i can play music/karoke files just fine along with the output onto the screen with the lyrics. however when i play music videos the videos play, the music itself its distorted and overtaken by a fuzzing etchy sound? is there a reason this happens.. all my videos are @ 720. for HD tv's
i for the life of me cannot figure out whats causing this.. the videos play fine in my windows media player but when i DJ. i dislike having to use WMP during my shows
geposted Wed 01 Jun 11 @ 1:28 am
What is your hardware configuration?
geposted Wed 01 Jun 11 @ 7:40 am
its an HP G60 Laptop, Dual Core CPU 2.00Ghz
3GB Ram
32-bit Opt
Conexant High Def SmartAudiot221
Intel(R) HD audio HdMi
1366x768 display
all vids are in 720 format. plays fine on windows media player.. videos them self play on the virtual dj software, just no sound.
3GB Ram
32-bit Opt
1366x768 display
geposted Wed 01 Jun 11 @ 10:08 pm
Make sure you have the correct codec added to vdj
geposted Thu 02 Jun 11 @ 12:10 am
i think i have all the right codecs. i have also installed the k-lite codec pack.. and still nothing
geposted Thu 02 Jun 11 @ 1:06 am
all codecs in the right place.. still no sound.. all distorted and fuzzy like a scratched record.
geposted Thu 02 Jun 11 @ 1:17 am
problem fixed.. thx for the tips anyways
geposted Thu 02 Jun 11 @ 3:36 am
What was it?
geposted Thu 02 Jun 11 @ 12:01 pm
ok so they worked for about a day. and now the videos don't even show up on either deck. sometimes i get 1 to play on the Deck A. but nothing will Work on deck B. all the codecs are right. the music sounds good. the screen itself is just black. i can use effects. and the effects will appear perfectly, at a loss again on whats goin on with the program
geposted Fri 03 Jun 11 @ 3:26 pm
What type of videos are you trying to play?
geposted Fri 03 Jun 11 @ 3:57 pm
music videos in wma 720 format. virtual dj will play 1 video per side when i start the program.. once i try to load the vid. the slots go blank and the video plays only music. no visuals of video.
geposted Sat 04 Jun 11 @ 5:49 am
meant. once a video is played on deck a&B after that the next video i load into that side. will not show up..
geposted Sat 04 Jun 11 @ 5:50 am
heres my problem I'm trying to record (mix) a video works b video works, but when I try to mix them b will always freeze, it's not the video
I've tried the same video a& b & it works . Its only when I go to mix one of them will freeze. audio is still ok just video problems
window7 pro 64bit
6 gig ram\ 600 harddrive
1 gig decateded to video
window7 pro 64bit
geposted Sun 21 Aug 11 @ 4:23 pm
