My Partner found this software to use with our website. http://www.djintelligence.com/
Does anyone use booking software if so what are they called?
geposted Wed 01 Jun 11 @ 11:39 am
I use them. I think the service is great and for a year membership is pretty cheap. Its customizable so you can make it fit with your website or you can use theirs with a direct link.
You can go to http://dj.omegaman654.com to check it out. Use the Menu Bar to select Song Search (not the left menu, I have to fix that). Once you go to Song Search you can look at all the services.
They offer a direct link for payment gateway (Paypal, google, etc) as well which is nice.
geposted Wed 01 Jun 11 @ 12:50 pm
I been using this service for years. Awesome product and great customer service. Highly recommend it
geposted Wed 01 Jun 11 @ 3:10 pm
I use it & it works great. Also recommend it.
geposted Thu 02 Jun 11 @ 12:40 am
You can also try DJ Event Planner. It is very comparable to DJ Inteligence but it also has email capbility which is a big plus. Give Troy a call and tell them John from NightBeat Entertainment sent you.
geposted Thu 02 Jun 11 @ 2:50 pm
Thanks Guys, I am going to use them. Wonder if they have referral awards for one of you.
geposted Tue 07 Jun 11 @ 3:10 pm
They do and I will gladly accept it! :).
geposted Tue 07 Jun 11 @ 4:23 pm
