I have been using VDJ 7.04 for a few weeks now and just started getting this error the other day. I did a VDJ reinsall (reapir), I have not tried to uninstall and reinstall. Any ideas why this could be happening?
It does not seem to effect the program. I just hit ok and all seems to work fine. But jobs kick back up next week and I would like to get it sorted out before I make any drastic steps like uninstalling. Thanks
PC is Win 7 64 bit
PC is Win 7 64 bit
geposted Thu 02 Jun 11 @ 11:41 am
You will need to install DirectX 9c on your computer (Some plugins require this):
http://www.microsoft.com/downloads/en/details.aspx?familyid=2da43d38-db71-4c1b-bc6a-9b6652cd92a3
geposted Thu 02 Jun 11 @ 5:23 pm
I had that installed, not sure if a Windows Update killed it, but it works perfect now. Thanks!
geposted Fri 03 Jun 11 @ 9:02 am
