Ok, so I switched my setup back to a two deck setup, from an experimental 4 deck setup, and since then my V7 (single, deciding on getting another, not looking good with the problems) will play tracks like they are 10 times the tempo (pitch at 0 on the deck and on VDJ) until I switch the motor off and then they play at normal speed (or whatever the pitch is actually set to).
I have tried re-installing the V7 driver, and resetting VDJ to factor settings.
This is driving me nuts, I've only had these things for 5 minutes and they are causing me all sorts of headaches.
Any help on this would be much appreciated.
Thanks
Thanks
geposted Fri 03 Jun 11 @ 4:42 pm
Ok so I un-installed VDJ and re-installed it and the problem is now fixed.
Second time it has happened today, so even though it is fixed, any advice on this would be great as I can't afford to be doing this all the time, especially if it decides to do it before a gig etc.
Cheers
Cheers
geposted Fri 03 Jun 11 @ 5:17 pm
I'm still having the problem regularly, and dare not gig until its sorted. Please can anybody offer any advice/support with this.
Thanks
Thanks
geposted Thu 30 Jun 11 @ 12:34 pm
It's because both decks are set to MASTER.
Did you follow the V7 setup instructions from the Hardware Forum ??
https://virtualdj.com/forums/130863/Hardware_Technical_Support/Numark_V7_-_Setup_-_1_and_2_unit_settings.html?page=1
geposted Thu 30 Jun 11 @ 2:56 pm
