I have been using vdj for a few years. I decided to try the best of both worlds so I decided to buy rane ttm57. I like both of the software programs. But I would like to know if there is a way that I can get all of my cue points and bpms on vdj into serato. I am using the MAC version. Thanks for your time. As you can tell.....I am new to this.
geposted Fri 03 Jun 11 @ 5:07 pm
Well as for the bpms you'd have to write them back to the ID3 tag because Serato will read them but as far as cue points that's a no go unless you put something in the comments section of your tags.
Huey
Huey
geposted Fri 03 Jun 11 @ 5:23 pm
