Forum: Old versions
Topic: Songs Loading slow on Deck.
I have the latest version of Virtual dj, which is 7.0.4. When ever i drag the songs on the deck, it takes anywhere between two minutes to just stop loading on the deck. Am not doing Video mixing, just simple mp3 mixing.
So can some one help me.
geposted Sat 04 Jun 11 @ 2:00 pm
Please register your VirtualDJ LE serial number on the page https://virtualdj.com/users/edit.html and then download the latest version from https://virtualdj.com/download/updates.html
Check that your sound settings in CONFIG -> Sound Setup are set to the following:
Inputs: None
Ouputs: Headphones
Sound card: DJ Console 4-Mx
Click APPLY.
If a song takes a long time to load, then this may be due to performance issues. Common causes are:
* You are using a computer that does not meet the recommended system requirements listed at the bottom of the page: https://virtualdj.com/products/virtualdj/ - Loading on old computers or on 'NetBook' computers will be very slow due to the low performance of these systems.
* You are using an external hard drive that may have gone to sleep. This will cause a delay when you go to load a song from it, which can be anything from a few seconds to almost half a minute on some badly designed drives. If your external drive takes more than a few seconds to wake from sleep, you should replace it with a better quality and faster drive.
* You are using a slow hard drive, or slow USB connection (Some much older computers may have USB 1.x ports instead of 2.0) If you are loading videos, these are very large files (Typically 10x the size of a normal MP3 audio file), so they will naturally take much longer to load. A 7200 RPM or faster drive is recommended for videos.
* You are playing videos and have the 48Khz resampling option under CONFIG > Performances set to quality rather than fast.
* The SpeedLoad setting, which can be toggled on/off via the Registry Tool https://virtualdj.com/addons/2170/Registry_Tool.html - This option is designed to slow down loading on older slower computers to prevent sound break-up that could occur due to the processor being too busy with loading/analysing the song. Sometimes this can be triggered on more high-end computers, resulting in unnecessary slow loading.
* You are loading a song that is longer than your MaxLoad setting which can be found in CONFIG -> Performances. Songs that are longer than this setting will be streamed direct from disk, which may cause you problems if your disk is not fast enough to be able to keep up.
Or there may be an issue in your computers registry.
