when i first started using netsearch (on another laptop) i had to re add the tracks add the tracks i'd downloaded from netsearch as they would not automagically apear in the search db, to do this i would right click on the netsearch icon and select add to search db, this would then add the whole lot in creating doubles of tracks, after doing a bit of research i found that within each pair of tracks one would be
c:\users\mattpattie\virtualdj\cache\COOL -TRACK.mp3
and the other would be
c:\users\mattpattie\virtualdj\\cache\COOL -TRACK.mp3
the double \ being the problem
is it possible in the next version to make the FIX button on the config>browser> remove all double \'s in the search DB as there iligal directorys anyway unless its a file share
Cheers
Matt Pattie
Cheers
Matt Pattie
geposted Sat 04 Jun 11 @ 2:20 pm
Check the Netsearch forum, theres a fix there. https://virtualdj.com/forums/146615/Premium_Members_Forum/All_my_cashed_songs_are_listed_twice_help_.html
Huey
Huey
geposted Sat 04 Jun 11 @ 3:39 pm
cheers for that ;)
this should deffinatly have been put into the fix button though. arr well, just hope it gets added in the next version (as its the first thing most people would try)
matt
matt
geposted Sat 04 Jun 11 @ 8:20 pm
