Hi friends,
I have another desktop running vdj now and it runs verry smooth with audio.. But I noticed that when I use the video-plugins my cpu runs out of control, and The video is out of time.. . What can this mean?
This is what I use
This is what I use
geposted Sun 05 Jun 11 @ 5:20 am
I was thinking if it's correct to copy all plugins from one pc to another. Or do I have to install them?
geposted Mon 06 Jun 11 @ 8:37 am
i would try to update OS (SP3), directX, drivers for video card (which is ? ...), and adjust a few things according to this guide, as your computer may not be that strong to run videos.
geposted Mon 06 Jun 11 @ 10:36 pm
Thanks for your reply,
I don't want to upgrade to sp3 because then I have big problems with my touchscreen. I can't turn my screen 180 degrees than.(and that's what I need).
This is what I reed on the box.
Radeon X1900 GT by ATI
256mb
gddr3 memory
dual dvi
vivo
Best regards,
John
256mb
gddr3 memory
dual dvi
vivo
Best regards,
John
geposted Tue 07 Jun 11 @ 10:37 am
Okay... Yesterday I updated my desctop pc.
Installed sp3 and a lot more that came with it. I did this step by step and one by one. One update couldn't be done, Some language-pack from net.framework.
My pc is running smooth now, only when I use my standard plugins (titler, random videotransition, firetext) the cpu will run op to 40 -50%.
Have to see what I can do to fix that..otherwise I can't use 3 plugins at the same time
geposted Thu 09 Jun 11 @ 2:39 am
