all my videos are in 720 format/wmv when i load my virtual dj pro software. 1 video will play in deck A. video wont load into deck B. the music will however play. and if i go to play another video on Deck A after the 1st vid on that channel. it too will not play. ive tried everything.. codec's are in order cuz it plays all my mp3's all my karaoke files and it'll play 1 single video (in full Screen) as well.. not sure whats goin on with it.. running windows vista. dual core. 1tb ext hd. gemsound ext soundcard for my gigs. i.e with exteranal monitors. etc
geposted Sun 05 Jun 11 @ 3:35 pm
It's loaded with bugs. Works on some laptops and doesn't with others. Some video cards don't like the taste of VDJ as well. Mine will freeze while using my Mixdeck if the screen resolution is higher than the skin size.
geposted Mon 06 Jun 11 @ 9:07 am
yeah im pretty much about given up on it. it only plays a video 1 time when software 1st loaded. after that it wont play another one.. and not sure of anything else to do.. guess i'll look into purchasing an ext video card that'll work
geposted Mon 06 Jun 11 @ 9:39 pm
