Topic: mp3 dj hercules
quick one guys..will this unit work on my back up mac 10.5.8 cheers
geposted Mon 06 Jun 11 @ 3:25 pm
Mac minimum requirements
1.5GHz CPU or higher / 512MB RAM
Mac OS® 10.4 / 10.5 / 10.6
Yes it will if it meets the above system specs. Cheers
Providing that your backup computer is Intel based with MacOS 10.5 or later installed then you should not have any problems. You have 10.5.8, so your O/S is OK.
MacOS Tiger is an obsolete operating system and is no-longer supported by VirtualDJ or Apple.
PPC (PowerPC) processor is also no-longer supported by VirtualDJ.
Your computer needs to meet and preferably exceed the recommended hardware specification at the bottom of the following page: https://virtualdj.com/products/virtualdj/
