Forum: Music discussion
Topic: Broadcast radio help
Hi i am broadcasting radio in virtual dj.
but i use the t.bone SC440 USB. How can i make a bind on windows to mute the mic or how du i turn down or mute the mic volume in virtual dj.
i tried with the skins mixlab but it does not turn down my mic voice. please help me i am a newbie
geposted Mon 06 Jun 11 @ 3:26 pm
Guess it will not work with your VDJ LE version.
Try a Mic, you can plug to your RMX and a broadcast software like EDCAST.
the problem is i dont have one to plugin RMX
OK, then you need to buy the Pro Full ;-)
Atomix offers to RMX user like you a nice dicount!
Insert your serial under Upgrade to VirtualDJ Pro Full @ https://virtualdj.com/buy/
I got an pro version from a freind. and can not type the serial on the web because he always have done it on he's own account. please help me.
Is it a secret or something?
You are not permitted to use the software of another user. Please read the following very carefully:
You are granted one license to:
- install and use the Software on one computer.
- install and use the Software on a second computer, if this computer is normally used by the same person and the Software will not be used on both computers at the same time.
- make back-up copies of the Software for archival purposes.
This license does NOT allow you to:
- rent, lease, sell, lend, distribute, publish, bundle or sublicense the Software or any part of it.
- rent, lease, sell, lend or distribute hardware on which the Software is installed, unless specifically authorised by Atomix Productions.
- electronically transfer the Software from one computer to another or over a network.
- decompile, reverse engineer, disassemble, or otherwise reduce the Software to a human-perceivable form.
- modify the Software or create derivative works based upon the Software.
For the full EULA - End User License Agreement please go to the following link: https://virtualdj.com/atomixproductions/disclaimer.html
I got it from a freind it is only installed on 1 computer?
only used by one person
