Hi,
Im user of virtual dj pro.
im useing:
laptop sony vaio
esi u46dj
turntables
mixer
serato time code vinyls v1
It is all going about that im looseing contol after few tracks.
i dont know why. everything is well pluged.
are the code time vinyls the problem of that? there is no option to swich to serato v1 vinyls.
do you have some kind of problem like mine?
please help
im useing:
laptop sony vaio
esi u46dj
turntables
mixer
please help
geposted Tue 07 Jun 11 @ 5:27 pm
try different vinyls, needles, rcas.
geposted Sat 18 Jun 11 @ 4:01 pm
I have the same problem. As a matter of fact, the software is still receiving the code but its not controlling the song at all. I would like to get this taken care of because it's the only problem I'm having on a regular basis.
geposted Mon 20 Jun 11 @ 2:19 pm
both of u guys post ur laptop specs
geposted Mon 20 Jun 11 @ 2:53 pm
Post a picture of your timecode config screens..........I wanna see where your gain is set at. I've had this happen also and it ended up being my gain was to low.
Post a picture please
Huey
Huey
geposted Mon 20 Jun 11 @ 3:17 pm
you also need serato cv2's, 1's don't work
geposted Mon 20 Jun 11 @ 8:25 pm
Refresh of topic;)
I still have the same problem. I was using program only with midi controller last time but I need a really stable vinyl control.
Signal is ok - circle.
Gain on a hardware mixer of audio interface is set to 0 (signal is ok).
I was trying also with line out of my stanton t80 and the same issue and the same with other sound card.
Im thinking at the moment about Traktor because I need stability.
Any help? :)
Any help? :)
geposted Fri 30 Mar 12 @ 10:26 am
by the way I was checking the same thong on macbook pro - the same + crashes of program sometimes :(
geposted Fri 30 Mar 12 @ 10:29 am
