Hi guys I have this soundcard http://www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=4115644&SRCCODE=PRICEGRABBER&cm_mmc_o=2mHCjCVybgwTyz__wyCjCVqHCjCdwwp&cpncode=21-117947097-2 will it work to que songs in head phone? I used to have one that was similar in settings but it broke. I only use the laptop to DJ with no CDJs or anything. THe problem I have is bleeding sound from the cue deck while one is playing. any help would be great.
geposted Tue 07 Jun 11 @ 10:05 pm
In theory any USB sound card should work.
It would be better though, to buy a professional multi channel (not 'surround') USB card with ASIO drivers, not a domestic/consumer model which isn't designed for the job.
geposted Wed 08 Jun 11 @ 6:59 am
Thanks any suggestions. As I said I dont use anything but my laptop to DJ on.
geposted Wed 08 Jun 11 @ 2:14 pm
I would recommend something small if you are not using any type of cdj's or turntables like the Numark DJ IO sound card very good sound card. I used that card for about 3 or 4 yrs and worked great for me
http://www.numark.com/djio
It is cheap as well. Bout 100 bucks if not cheaper now.
Hope this helps
Charlie C
Hope this helps
Charlie C
geposted Wed 08 Jun 11 @ 4:58 pm
thanks man checking it out now
geposted Thu 09 Jun 11 @ 12:10 am
