i have my mpd16 plugged in, but how do i make virtual dj recognize it?
And when it does, how do i assign samplers to it?
Thanks
Thanks
geposted Wed 08 Jun 11 @ 8:34 pm
You can use MIDI-controllers such as the Akai MPD16 only with Virtual DJ Pro, so you'll have to buy a license. After that you can assign wanted functions from Config-->Mappers.
geposted Thu 09 Jun 11 @ 4:49 am
I'm a pro user, and i can't get VDJ to recognize it. It works in acid pro,and with my sample banks, so i know the computer knows its there. It's not showing up under the config - mappers section.
geposted Tue 28 Jun 11 @ 10:27 pm
Only devices with built-in support are displayed in the mapper device menu. You should however be able to map the Akai MPD16 by selecting "Simple MIDI mapper" from the device menu.
geposted Thu 30 Jun 11 @ 12:29 pm
