hi gang:
i can not for the life of me map vdj 7
i need to start turntable 1 with letter "A"
i need to start turntable 2 with letter "Z"
i also use to map it so the mixer would slide to the left on turntable 1 with letter "A"
letter Z - the mixer would slide all the way to the right
i don't see these things in configure - map etc
please help
thanks in advance
please help
thanks in advance
geposted Wed 08 Jun 11 @ 11:32 pm
you can just map a key "mix_now" it will sync and crossfade to the other deck, but if the other deck is not playing it will start the deck.
otherwise
A= deck 1 play
Z= deck 2 play
you could also use "play_pause" "play_stop" "play_button", "play_sync" "play_sync_onbeat"
otherwise
A= deck 1 play
Z= deck 2 play
geposted Thu 09 Jun 11 @ 2:54 am
thanks so much
i will try this later today
but just to get this straight
lettter "A" will simultaneously start deck 1 and move crossfader 100%
letter "Z" will simultaneously start deck 2 and move crossfader 0%
all using
A mix_now
z mix_now
all using
A mix_now
z mix_now
geposted Thu 09 Jun 11 @ 6:16 am
mix now is automatic, it will do it to whatever is not playing so you only need to map it once, and it doesn't need to be assigned to a deck, just write "mix_now"
geposted Thu 09 Jun 11 @ 9:13 am
