Hello everyone, I'm here today with a problem I'm running into when I'm using 4deck mode with dj4set. My setup is a set of logitech speakers with a 10" woofer connected to the dj4set by the aux cables; The 4set is connected to a aus eepc netbook with an external cdr/dvdr drive and 1gb ram. So I assume it's not the computers fault; I searched for a topic about this problem and I found the IRQ solution to poping and crackling but it said computers have 16 irqs. Mine had irqs ranging from 0-180 It said to change any soundcard irq that was conflicting to an open channel. I really couldn't differ the sound cards from the others? Would buying more ram fix this? I have 1gb currently and when it 2 deck mode the cpu bar ranges from 50%-75% full while playing/loading tracks; while four deck mode its always 80%-100% full if im loading a new track especially. Please give me some imput on this problem, what have you guys done to fix the crackling?
geposted Thu 09 Jun 11 @ 3:51 pm
which specifications has your laptop? Wich sound card do you using ?
geposted Fri 10 Jun 11 @ 4:48 am
Well, to be honest, running 4 decks on a Netbook, you are sort of asking for trouble. These computers are simply not made for these kind of performances.
You can try to improve things a bit by applying the recommendations of the following guides, but in the end, you'll always run into issues because of the lack of power.
https://virtualdj.com/wiki/Common%20PC%20Performance%20Issues.html
http://ts.hercules.com/faqs/eng/her_eng_00364.pdf
geposted Fri 10 Jun 11 @ 7:21 am
So if it out'd picture on a lcd and upgraded from 1gb ram to 2gb ram i would still have problems?
My specs:
Manufacturer- ASUS
Model- Eee PC
Processor- Intel(R) Atom(TM) CPU N270 @ 1.60Ghz 1.60Ghz
Installed memory(RAM)- 1.00GB
System type- 32-bit Operating System
My specs:
Manufacturer- ASUS
Model- Eee PC
geposted Fri 10 Jun 11 @ 9:55 pm
