Im using a Mixtrack with VDJ 7 Pro and was wondering if the way a couple of the buttons act can be changed in the mapping options.
- if scratched when playing, can the song continue play from where it would have done if there had been no interruption/scratch? (the same as the numark CDN-95 in scratch mode 3)
- when stopped, can the cue button be used to rewind the track to start / cue point ? as i cant find a way to put the track back to start!
- how can i get the effect control knobs to turn the soft knobs?
- how do you use the numark and pioneer modes of the _button codes? i tried typing for example cue_button "numark" but nothing responds
By the way the mixtrack i have came with traktor - i assumed they were all the same but just came with different software but i noticed the EQ kill buttons at the top are actually mapped in VDJ to control hot cues, so maybe the mixtracks that came with VDJ had different labeling or something !
Any help or codes would be much appreciated! :)
geposted Fri 10 Jun 11 @ 2:50 pm
i like the loop buttons Led's to NOT blink on the mixer, when selecting them to auto.
weird design flaw: why wouldn't anyone prefer auto loop (annoying persistent blink) to manual loop (steady on)?
fix:
LED_LOOPMODE
var "shift_loop" ? on .................. (delete "blink" after ?, before 'on' )
fix:
LED_LOOPMODE
geposted Sun 28 Aug 11 @ 11:46 am
